Hello,
I am working on a friend's Cruiser - 2006 w/ 245K on the 2UZ-VVTi. It's been consuming LOTS of oil for a while, and we finally started digging into it. The engine was opened by a previous owner - no idea why or what was done. Based on the poor timing belt/water pump job I corrected a year or two ago, I suspect this prior engine work is a factor.
What's odd is that based on the oil consumption, I would expect the back of the truck to have oil soot around the bumper or at least have a blackened tailpipe. Neither are evident and there are zero engine leaks. I suspect the cats are fouled b/c it's throwing codes (don't recall them off the top of my head). Regardless, no soot, no smoking on idle or startup, no visible smoke when following on road. It's odd. Thoughts?
We ran a compression test and leak down test (both were run on a cold engine).
Compression numbers (specs from FSM page EM-3: max 199 psi, min 149 psi, <=14 psi difference between):
1 - 178
2 - 180
3 - 174
4 - 180
5 - 155
6 - 175
7 - 185
8 - 190
The leak down test on #5 showed a 54% flow, and it was clearly coming through the intake system (throttle plate held open). This tells me there is something amiss w/ the intake valves. I think I should conduct a wet compression test on #5 to check piston ring integrity. If the number does not change, would it be safe to have confidence the ring is good based on the other numbers? I concede there's no way to really tell until the intake valves are addressed.
We're debating on next steps - in situ engine work (pull both heads) or pull the motor.
Reasons to pull motor:
1. The learning experience and fun of it.
2. The steering rack needs to be replaced.
3. Flex plate should be replaced (long-term starter issues, since corrected, chewed up some teeth)
4. Opportunities for cleaning, addressing some brittle/damaged engine harness connectors, etc.
5. Upgrade opportunities, if any.
At 245K miles, it seems now is a good opportunity to do more engine work than just heads. I'd appreciate any thoughts, insight, suggestions. In situ work or pull the motor?
Options we're considering if pulling the motor:
1. Full stock rebuild - local or ship to an experienced rebuilder.
Anyone have suggestions of good 2UZ-FE rebuilders?
2. Full rebuild w/ upgrades - port/polish? 1UZ connecting rods in case of a future VVTi-compatible supercharger installation? Anything else worth considering?
3. JDM import swap
4. Junkyard swap (disinclined to go this route)
Funds are not unlimited although we're willing to spend some money for longevity, efficiency/power increases, and doing all that's reasonable/recommended through the process. This truck will likely be in the family for decades.
What are your thoughts?
Oil consumption and lack of evidence other than codes and disappearing oil on the dipstick?
Rebuild heads or rebuild motor?
Recommendations on top-quality, experienced rebuild shops.
Pull motor or leave it in place?
Anything I'm not thinking of?
Thank you,
Erin
1 - 178
2 - 180
3 - 174
4 - 180
5 - 155
6 - 175
7 - 185
8 - 190
3. JDM import swap
Thank you,
Erin
