A thread in "Outfitting" was asking about "T-Max" winches....and whether or not they are any good.
I don't have any experience with them so I can't comment on their reliability.
I did take the time to look up the "specs" on both a TM and a Warn, and on the surface the T-Max looks appealing. When you look at the performance specs. however.....it soon becomes evident which one is the true workhorse.
I have cautioned people in the past to look at the line pull figures for any winch they might be interested in....but first lets look at the basic features of both.
TM rated line pull (12,500)....the Warn (12,000).
TM motor 6.6 hp/12v.....vs. 4.6 for the Warn (advantage TM).
TM gear ratio 265:1.....the Warn 261:1 (very similar).
TM drum 2.52".....the Warn 3.5"
TM has 94' of 3/8" cable......the Warn 125' of 3/8" (advantage Warn).
TM weighs 93 lbs.....the Warn weighs 136 lbs.
Both come with a roller fairlead, remote control, clutch, brake, and require about 650 cca. to operate efficiently.
Now lets look at the line pulls:
TM first layer 12,500..............Warn first layer 12,000
TM 2nd layer 9,210.................Warn 2nd layer 11,120
TM 3rd layer 8,030..................Warn 3rd layer 10,340
TM 4th layer 6,894...................Warn 4th layer 9,770
TM no more layers...................Warn 5th layer 9,250
The Warn has more "grunt" on its 5th layer than the TM does on its 2nd.
The TM from its 1st layer to its 4th layer gives up a whopping 5,606 lbs. of pull.
The Warn by comparison gives up only 2,230 lbs. of pull, and still has another layer to go.
If TM has not put out some inaccurate specs. then IMOP they have managed to produce a woefully inefficient product.
Just thought you'd like to see this.
