2001LC
Lubing propeller shaft (AKA Drive Shaft) Tight seals may cause Hydro Lock
Lubing with NLGI #1Grease; Manufacture recommends NLGI #2
Has anyone here tried this, have any opinion or can offer knowledgably comments on using this lighter #1 grease for this application?
My concern is: will the NLGI #1 give me sufficient shear protection
I’m using: Amsoil MP synthetic lithium complex grease EP fortified GC LB NLGI #1, Mobil 1 NLGI #2 for U-joints & wheel bearings
A little background of why I used this #1 grease:
I had finally gotten around to lubing my U-joints and sleeve’s on the front and rear PShaft (Propeller Shaft, AKA Driver Shaft) while doing my 90,000 mile maintenance, well closer to 100,000 miles. I noticed the PShaft sleeve yoke kept extending but no grease was coming out around the seal, I pump and pump that NLGI #2 lithium grease in until finally a small amount of old grease followed by a small amount of new grease started coming out around the seams of the metal plate in the end of the shaft (the pocket of the sleeve yoke) then just a bit from around the seal, but only after extending the yoke a great deal more than one would think was advisable. This was the front shaft the rear extended much more without any grease coming out. I became concerned about the amount of pressure on the bearing of the transfer case and differential’s even more so once I read a thread in FAQ under 100-series Cruiser titled:
Lubing the Driveshafts: too much grease?
So I pulled the front PShaft and cleaned it, while spending about and hour and half cleaning I came up with the idea of using NLGI # 1 grease, to see if it would flow better. Most of the grease I cleaned out was what I put in 1000 miles ago, not much old grease in their (probably not lubed in 70,000 miles if at all) I followed the manual (except I used NLGI #1 grease) and applied greased to the propeller shaft spline and sleeve yoke surface during assembly. Found it necessary to remove the grease zerk to alleviate the pressure before I could slide the yoke in. the manual then said to install the PShaft and pump in grease until it begins to flow. I decide to fill this with grease on the bench, placing the PShaft between to concert structures with wooden blocks on each end for protection. I pump until grease started flowing out the cup end of the sleeve yoke then the seal. I’m sure I put much more than 500lb of pressure on the assembly before any grease came out, good thing I did this off the TLC. I then pump in grease to extend the PShaft (1 inch short) short of the length I needed to install, I did this to make install easier and create a void to help the grease flow and the sleeve yoke compress the inch or so easier during operation on the road. I extending the yoke the last inch or so by hand, applied thread lock and tighten the nuts to spec 59 ft lb.
I have not done the rear Propeller Shaft yet, when I do, I plan on leaving at least a 2 inch void and kept the weight of the vehicle on the rear axle so that the rear PShaft will be in the most neutral compressed position I can get it in during install of the PShaft.
I will wait until I hear from all the great people on this board, before I decide on which grease I use in the rear Propeller shaft AKA rear Driver shaft and if I leave the NLGI #1 in the front or not.
THX From Colorado
2001LC
THX From Colorado
2001LC
