Maybe the service interval is overkill, or maybe the short service interval makes sense for the u-joints (it does imo if the vehicle is seeing a lot of mud & water etc) so the service interval for slip joints was thrown in for good measure, while the grease monkey is doing the u-joints.
The frequent lubing recommended will "clean" the seal area by pushing out the contaminated and emulsified grease and replace it with new. If there is no regular service then the "grime" could harden and block the seal. Over time the oil in any grease "seeps" out of it's binders and takes the lubrication with it.
Propeller shafts were hydro locking causing thump on slow take off from stop and thump at slow speeds on minor bumps.
I doubt the service interval is too conservative. I think it is more likely that a lack of service is responsible for these seal problems. The grease is actually "consumed" in this slip yoke application with each extension or compression. The grease coats the shaft on extension and then the grease left exposed after compression is washed away. The grease near the seal is contaminated with water and road grime carried past the seal on compression strokes in the same manner. The frequent lubing recommended will "clean" the seal area by pushing out the contaminated and emulsified grease and replace it with new. If there is no regular service then the "grime" could harden and block the seal. Over time the oil in any grease "seeps" out of it's binders and takes the lubrication with it.
Very possible, lots of complaints on Taco and Tundra boards about drivetrains being under lubed when new. Lubing properly solves the problems.I have a 200 series.
Could the shaft not be greased on mine properly with only 1300 miles on it?
I am getting the thump from underneath and thought it was the tranny until I did some searching under thump or clunk in the forum.
So how exactly should I approach this with the service area?
My point was exactly that, the engineers would not design the propeller shafts to act as shock absorbers, but to move as freely as possible while not allowing contaminants in through the seals.The slip joint is not a shock absorber designed to protect the T-Case. My guess is very few cases of "hydrolock" if they exist at all have resulted in damage. The truck seems just as likely to transfer a damaging amount of force when insufficiently lubricated and "thunking".
If actually "hydrolocked" wouldn't the drive shaft severely limit rear axle travel and result in very poor and noticeable handling and ride problems.
Posters on the board claim to feel the power difference between premium and regular!Surely they would notice if the rear suspension was totally inoperable.
By the way thank you for the heads up on the Moly grease:whoops:By the way - make sure you don't ingest the moly. It is somewhat toxic. (Regular plain grease probably won't hurt you if you forget to wash your hands before eating with your hands, but additives like moly should be avoided in your diet.)
I would just get under there and start pumping man. I use NGLI #2 on all my zerks, dont need to overthink it.I am trying to do basic drive shaft maintenance on my 2004 LX470.
I have read the "official clunk thread" and a bunch of other posts about proper maintenance of our "drive shafts" and i think i understand the basics but there are still a couple of things im not perfectly clear on.
Here is what i think i understand... If i get an NGLI #2 lithium based grease i can use that in the Spiders and Slide Yoke. If i wanted to go the extra mile i could get a second grease gun and grease the Slide Yoke with a moly fortified grease for extra protection but this is not required and i should not use the moly fortified Grease in the spiders because that could cause damage. If i run into trouble and grease doesn't seem to be moving past the seals i can up the interval and use the lighter more viscous NGLI #1 grease until it frees up any clogged old grease and i can switch back to NGLI #2
If this seems right ill go get under my rig and start pumping. Any advice or correction would be greatly appreciated.
Thanks!!
