Apologize for the 2nd post on this, but my first was dug inside my build thread and I need some advice on the topic below, thanks.
so here is where I need some advice. This is the first type of rust repair that I have done to this extent. I have read a ton and think I can weld in patch panels no problem but when looking at this I got nervous about body flex.
The situation: what I would like to do is to pull the panel as I have outlined it in the 2nd pic. The red are the cuts I will make on the crossmembers and the yellow is the whole piece that will hopefully come out in one piece. Once I cut the cmembers and drill out the spot welds that piece should come off and I will be able to really get at that interior rocker to do rust repair and coat in some good paint.
The problem: I have read before about body flex. I am worried that if I take off this much metal that the body will flex and I will have problems realigning body panels, doors and such. Is this concern warranted? or should I not worry about it? Looking for opinion from the gurus here whom have some good body work/rust repair experience. I plan to first strip down the lower portion of the body so I know what I am working with and then go one section at a time around the vehicle, patch panel, paint etc., so there will probably be only this panel off on it's own, not both sides or other panels at the same time. I am thinking that if I go one section at a time it will help the body stay stable and not flex at all. Any opinions, comments on if I need to brace this area or not are appreciated and where I would brace it cuz I can't see a place to do it.
