Hi fellow cruiser heads,
I am at the point of frustration with my steering. I am starting to feel like I am the only guy that has had this happen to his 40, but I am hoping there is some one amoung you that can help or know the fix for this.
The issue is my drag link is contacting my drivers side shock as it swings through its arch. This has been happening since the HFS 4" lift was put in with the 2.5" shackles. I was told by ccot that the lift is too much (Not recommended ) so to speak. I require this much lift for my tires 33X12.5 not to rub with flexing.
My thoughs so far:
Does any one make a longer drop pitman arm?
A thinner bodied shock?
An upper shock mount that tilts the upper shock out & away from the drag link?
Anybody had this problem???? What is the best fix????
Thanks
My thoughs so far:
Thanks
