Normally, I am all about OEM, but someone recommended K&N air filter for my SuperCharger? It will flow more air? Any comments?
Thanks...
Thanks...
I have an open kit for my 95' S/C. Personally, those that have never had an open air kit have no idea about the benefits. YES, they are give you more power..about 8 more h.p. I have had mine on for 10 years with and with and without the S/C. BUT, K&N does have the pink fluid on their filters. Buy another type that does not have the fluid. There are dry filters out there. The K@N filters will gunk up the sensor with the pink stuff. I have my snorkel inlet pointed directly at my filter and no doubt....it gives you more power. You can't deny the laws of physics...more air in an engine= more power.
airlaird
I've read in the off road mags and heard on the truck shows (Xtreme 4x4 & Trucks) and from K&N that the K&N fillters better and flows more air. They reccomend the use of a K&N.
I have always had good luck with my K&N's so I am suprised to hear the negative reviews.
Have you ever been in very dusty conditions or had an oil analysis? When I finally make to the sand dunes down by the Gulf I think I will go ahead and switch to paper. At least while I'm there.
I never got an oil analysis, I just check it myself to see if it looks dirty. I drive about 50K miles a year and it always seemd like my oil got darker quicker when using the stock filter instead of K&N. Never done any scientific testing though
So is eveybody saying that there is a lot of the filter oil that blows through and causes issues?
Looking at whether an oil is dark or not tells you nothing about its condition.
K&N Filters allow a lot more dirt in. The reason they are popular with the off road RACE crowd is they will handle a lot more dirt than paper before clogging. The fact they allow more dirt into the engine than paper is irrelavant to the them, because their engines are rebuilt regularly.
In addition to allowing more dirt in, as others have said the oil on the K&N ends up on the hot wire sensor and causes problems with it. The stock filter on the 80 is great, and the OEM one can be washed several times.
I have to disagree that they allow detrimental damage to intakes since I have clocked over 300k miles with K&Ns in 3 different vehicles. I know others who have as well and I have never seen an engine come apart. The only intake/engine problem I ever had with any aforementioned vehicles was recently on my Ford Taurus after I reoiled a K&N and the MAF had to be replaced (under warranty). I learned later that a wipe of the MAF with a cloth would probably of fixed it. Anyway, I will no longer clean and reoil. But, I like the free flowing air so I will replace when dirty and swtich out for the trails. If I am ever convinced that the paper filter flows as much as the K&N I might change my mind.
Doing an oil analysis probably wouldn't be a bad thing.
So in other words, in 300,000 miles you have only had one MAF fail from the K&N filter. BTW, did your other vehicles have a MAF sensor, I would bet not.
As far as the freer flowing air, I don't buy it. At best you might see a 1hp gain, but auto manufactures would be putting in larger air filters if there were to be any horsepower gain.
As far as lots of people running them in street cars, who cares? Many people when tuning their cars put lowering springs in without shocks and do many other things that cause their cars to perform less than optimal in the interest of what is cool, that doesn't mean it should be done.
IMHO more than worthless mod
Cheers,
Sean
