Thread title updated....See below.....thanks!
Abs maybe for the plugs??? Just a guess....
PS res low or empty?? If so, fill it and start it up- have someone work the wheel. Mine sprung a leak where it is spiral wrapped and goes thru the core support to the cooler.Ahhh yes you win half a banana! ABS has been deleted so that covers that, thank you.
Now the leak for the bonus round....
time to get a flashlight and crawl underneath, Its kind of a PITA, but follow the trans lines to the bottom of the radiator. You can see them under the shroud, should be able to tell which one is leaking if its that quick. Check the trans fluid too.
easy fixes are nice sometimes, and you git a nice anti-corrosion coating on your Truck
Maybe wash that area off very well (soap and water) from above, the side, and from below, let dry, then restart engine turn wheel once side to side, shut off engine, take a bunch of photos of the PS hoses, pump, gear, etc, examine photos on a PC (larger screen) looking for the leak.
