77CruiserDog
GOLD Star
- Thread starter
- #361
Hose, pipe and hose clamp replacement
There are certainly merits to refurbushing items yourself. One tool I've been using a lot is a bench grinder with a brass wire wheel. It makes hardware look brand new. I'll post some pics soon.@77CruiserDog I’m over here with a mini drill-mounted flap wheel doing some exhaust and coolant pipes. Maybe I should just buy this crap.
Just read through your whole thread - amazing work! Wanting to do pretty much the exact resto steps you're going through, albeit a ton more rust repair. Thanks for documenting so well - helpful to add part numbers, amazon links, etc like you have. I know that takes extra time and effort over just doing the work and we appreciate it greatly!
Very early - doing all mechanicals first. Front axle is out for hub rebuild, pinion and housing seals, brake rotors, calipers, lines, backing plate eliminator, tie rod kit, etc. Huge bear on a rusty truck. Will try to post an update to my thread soon (link in signature)!Thank you for the kind words! I hope to add value to this amazing forum by including some of the parts I use and where I find them or how I do a particular task. I'm constantly amazed by other more skilled people who also post their work, but I do my best with what I have and I suspect others are in a similar situation. I'll be on the lookout for your resto!! What stage is it in now?
I appreciate your headlight info as well - I know many prefer the Koito housings, but I am wanting to do the Hella housings with LED H4 bulbs after your review.
Man, that looks great... You're now passing me in terms of progress.
Also, you might have made the right call on sending out for CAD plating vs zinc at home (is that zinc or CAD?)... My hardware looks great, but I've found the plating is a bit "fragile".. It tends to wear off with minimal contact. For example, using an impact on a nut or bolt, where the socket contacts, the plating will wear off a bit. I've heard this is too be expected but not something I was aware of beforehand.
