So, I’ve searched and tried the fixes that I’ve found posted so now coming for help and clarification.
82 FJ60 getting a 99 LM7. Alt is a cs144 4 pin connector but the stock harness has a single brown wire to the L terminal.
Bear in mind that I think my stock alt wiring was jacked!
Yellow from alt plug (turned to white, supposed to be y-w?) I hooked to the S terminal. The b-y wire from the alt was hacked up but I think I found it. It has continuity with the b-y on the charge light relay. I spliced it into the brown wire on the cs144 plug. Running, it’s getting 15v, nothing at the s terminal and the charge light stays on. What am I doing wrong?
Maybe someone can explain this circuit to me?
