No.Does the I-6 4200 Vortec have the same bell housing bolt pattern as the V-8 LS?
Thanks for the info. How about the NV4500 would that be a shorter assembly? I like the idea of using a inline 64200, matching 2wd 4l60e and an AA adapter to splitcase would all bolt up but transfer case would be REALLY far back. Short rear driveshaft and big tunnel mod required.
Cause it’s cheaper? Lot of work when an LS fits nicely in there
If I win the lotto and come upon absolute freedom of my own time, I will 4200 swap a 40 with a turbo. You can consult on it for meIt would be a LOT easier to turbo the 4200 in the 60 than turbo the LS in the 60.
But yes, an unconvential swap that doesn't make sense unless one already knew exactly what they were doing and weren't going to need to lean on a forum for help.
I think it would be a bad ass unique swap.If I win the lotto and come upon absolute freedom of my own time, I will 4200 swap a 40 with a turbo. You can consult on it for meI think it would be a bad ass unique swap.
No because it is a straight 6 and and great platform.Cause it’s cheaper? Lot of work when an LS fits nicely in there
I was wondering about the length.4200, matching 2wd 4l60e and an AA adapter to splitcase would all bolt up but transfer case would be REALLY far back. Short rear driveshaft and big tunnel mod required.
I looked into this swap before. The ax15 fits to this engine bolt pattern. The 80 series transfer case I believe Is a direct fit (ax15) without an adapter but I could be wrong. I do know that there is a ax15 adapter to split case. In theory this could work. I would just have to get some measurements.Yes. At that point I would probably just use the EMTech adapter and flywheel and AA bellhousing to the H42 or H55f though.
What forum tho.It would be a LOT easier to turbo the 4200 in the 60 than turbo the LS in the 60.
I'm a little late to this party but I have been looking at ways to put one of these Atlas 4.2 I6's in my 60. I had reached out to Emtech motorsports about an adapter plate for the H55F gearbox but then realized I could just buy a bell housing that would connect to a SBC and then buy their SBC to Atlas adapter. After that it comes down to input shaft length and clutch/flywheel etc.Does the I-6 4200 Vortec have the same bell housing bolt pattern as the V-8 LS?
or![]()
Atlas 4, 5 & 6 Cyl (2800-4200) to SBC, LS and BOP Bellhousing Adapter – Atlas Industries
*** We sold out Quick! Making more and back in stock this June *** Atlas to LS, SBC, BBC and BOP (and sometimes C) transmission adapter! Includes all bolts and extended bellhousing dowels for most GM V8 to Atlas fastening applications. (Torque converter and transmission pilot bearings may be...atlasinds.com
andBell housing adapter - EMTECH MOTORSPORTS
www.emtechmotorsports.com
TOYOTA 4 SPD TO CHEVY KIT
Chevy V8 to the 1974-80 Land Cruiser FJ40, H42 4 speed transmission, adapter bellhousing.www.advanceadapters.com
Ha likely. I’ve been researching it for a while and not on mud lately.You mean exactly how I described a few posts early in this thread?
