Hey gang - long time - no board. Hope everyone is well 190K miles, original engine.
1.) How much oil can you burn from old valve stem oil seals?
2.) No oil leaking while parked - nothing on driveway or in garage, but always oil around rear main / transmission. Front oil pump seal good, oil pan seal good, valve cover gaskets good. Rear main seal? Standard stuff with oil changes, but I clean that up
3.) No visible oil burn in exhaust. Cats burning it off?
4.) EGR is disabled.
Changing and adding oil regular basis, no compression check, engine seems to run fine. Just regular stuff for a 20 year old truck. Oil is going somewhere. Comments or ideas welcome.
_________________________________________________________________________________
Going to post WTB, but thought I'd ask since some of you guys that have stuff laying around. I don't have the space. Have traded stuff here before and given things away.
Need one center cap, '97 16" alloy. Somebody decided they needed one off my truck. Will be painted black so can be worn.
Need one interior black triangular trim piece cover PS rear view mirror bolts. Broke old one while putting new piece of belt mold on door.
Thanks and take care.
