- Thread starter
- #21
What's it hurt to buy one of those refrigerant refill kits from Autozone that has the guage on it? Wouldn't I be able to just refill my system with it and also watch the guage it comes with for leaks?
The gauge will not help you find the leaks. You need to determine what the problem is before you add freon. You could always put the gauge on it and see if it is out of freon.What's it hurt to buy one of those refrigerant refill kits from Autozone that has the guage on it? Wouldn't I be able to just refill my system with it and also watch the guage it comes with for leaks?
IF the system is not working because of a low refrigerant charge (trinary switch prevents this) and IF the leak(s) you have are not major, then you could add as much of a can as the system will take (under static pressure) and hope that it is sufficient to activate the trinary switch which would then allow the compressor clutch to engage.
I'm having this same issue now! (Boston here, but VERY minimal rust underneath due to an OCD owner )
Previously, the AC Light would flash then clutch would disengage. Dealer recharged, found no leaks, and wanted $400 to investigate a relay underneath the fuse block in the engine bay. I hadn't had time to research everything myself so I declined that, bought a new relay (P/N 90987-02028) per 'Mud and other Lexus/Toyota site threads, and bingo, problem was solved.
Then, yesterday, same symptoms as OP. Fan blows, AC light stays on but no clutch engagement!
For New England, my truck is about as rust free as you can get so I'm doubting corroded lines but not ruling it out.
To update you guys, I got one of those AC recharge cans with the built-in guage. Cost $50 btw, kinda more than I expected to pay.
Yup.
BTW I checked the little glass viewport to see if there is any freon in the system and it looked bone dry.
Sight-glass is useless unless the compressor is running, it is not a 'dipstick' for your refrigerant level.
But anyway, here's what I did:
Started the car, turned the AC on and set fan speed to maximum, and temperature to MAX COLD.
Unscrewed the L port on the freon tubes under the hood, and hooked up my recharge can.
Always hook your can up before starting the engine and turning on the A/C controls. That way you aren't dealing with any rotating fans, pulleys, belt, etc..
Pressure said 0. I guess that may already say that I have a leak.
Yup.
I pressed the trigger and started transferring freon into the system. At no point did the AC compressor audibly kick on. I don't however still know where it is to confirm whether it's spinning or not.
Lower drivers side of engine. directly above your oil filter. You will see the serpentine belt wrapped around the pulley. That is your A/C compressor.
I stopped transferring then the pressure read just over 30psi. Keeping the guage on for a minute, the pressure didn't seem to go down. However, after driving for 2.5 hours and connecting the guage again, the pressure now reads ~20psi. Not sure if that's expected or if it's indicative of a leak.
IF your compressor was not engaging (and I am fairly certain it was not), then it is difficult to get much refrigerant to go into the system (even without a leak), because there is no vacuum to help take it in (system pumped down), and no suction from the compressor. So basically, you were trying to read 'static pressure' with an inaccurate gauge. The low pressure could be the result of a significant leak or you may have simply gotten only a small amount of refrigerant into the system.
What do you guys think?
I think you should take it to a shop and let them look at it. You've already spent half of what they would charge to take a quick look at it.
Yeah. 10-4 Flintknapper. My only ac shop in my area is closed. Might be open only seasonally. I haven't seen them open in a while, and I was too itchy to get into it, so I had to try. BTW the sight glass didn't show anything even after I put the freon into my system, and I checked it when I had the AC button on, with fan blowing and all that. But I guess that could still be an indicator of not having had a vacuum before pumping into it.
I guess next stop is the AC shop. Would they even do something like the capping of the lines going to the rear? I live in NY so car repair places are notorious for selling you on the most expensive possible thing. They oftentimes just refuse to do work like that, insisting on doing the full replacement of the line, which is unnecessary for me and too expensive.
Thanks again for your help
Yes, quite possible.
I understand. And we generally encourage folks here to try to do their own work (when/if in their scope of capabilities). Even if you did not yet need your A/C for 'cooling' it still needs to be operational when you use your heater (if the weather is humid) in order to defog your windows. A/C removes moisture from the cabin air as well.
Yes. It wouldn't since the compressor wasn't running to circulate the refrigerant and oil. The only other time you are likely to see anything in the sight-glass (compressor off) would be in sealed system (no leaks) right after you shut the unit down...as the high and low side 'equalize'. The sight-glass CAN be used as a remedial way to determine if the system is moving refrigerant properly, but IMO it should only be used if you don't have a set of gauges, can't get/borrow a set of gauges or are so far out in BFE...that you need to do the job right now and fix it correctly later.
Not really. Under vacuum the refrigerant would be 'drawn' in. The only time you are 'pumping' it in would be at atmospheric pressure (system open) or under low static pressure (lower than the refrigerant container can supply). No matter, semantics...mostly. I'm pretty sure you have a significant leak someplace.
That's a good question. I suspect most shops would be hesitant to deviate from the original design of the system.
I live in NY
Yes, very sorry to hear that.
Not uncommon, many places. Especially if they think you don't know anything about it.
If you find that your rear lines are the issue and you don't require/want rear A/C I would definitely cap them off. It is something you can do yourself with a minimum of tools and know-how.
Da Nada
