im contemplating using an FZJ80 T-case in a Competition Buggy Build. 2500lbs 170hp Portals & Rear Steer.. ive got a few questions for guys that have 80's or use this case
1- i know the VC Transfer Case is 125lbs.. how much lighter/Shorter is the Non VC Case?
2- how quick is the CDL to Lock and Unlock, (will it ulock if bound up)
3 - Anyone ever Use Cutting brake, or a rear E-brake to Do Front Digs with the CDL Unlocked?
My Theory is that with all 3 Diffs unlocked the rig will be more maneuverable with less bind in the system.. but im curious if the Lack of Digging may be an issue. My idea is to use a Separate Master cyl/Pedal for Front/Rear Brakes so i could stab one side or the other with the CDL Unlocked and do some front/rear digging. But more importantly i could give just a little bit of brake to one side or the other and Overdrive one side at a variable rate maintaining traction.
Or i just Slap a Dana 300 in it and call it good.
