2fpower
SILVER Star
Ok, first off I don't consider myself very brave when it comes to playing with electronics. I can take a computer apart, but 50/50 if it will work afterwards. So with that brief introduction, with all the postings on MUD to install a Scion radio, I figured that I could do it. With the help of Rockjock82, SamStewart, and others too many to mention, I finally got mine working. Having said that, I wanted to post up more of a step by step manual to get one to work.
First off, why the t1819 unit. First off is made by pioneer, so it is good quality. It is available in late model 2011 and 2012 scions. It is found on clist and ebay for about $100 bucks. It has bluetooth, HD radio, iPod and data connection standard. If you buy most head units (HU), they are all "ready" which means you have to buy a $75 harness to complete the connection. On top of that it allows for handsfree phone if you add the microphone (here is the harness deal). It is Sat ready, I am not covering this part, as did not install myself.
Here is a link to the manual. http://www.scion.com/assets/pdf/audio/2012_Pioneer_Audio.pdf
Once you have this all installed, you now have a cool radio in your rig that no-one really wants to steal, because it is a factory radio!! one note here: I am looking to scrape off the scion label and put Toyota. If anyone has a cool idea how to do this, post up.
Ok, let's get started. First off is the buying. Search for t1819 on ebay. also look for pt546-00130 or t10004 or alcp-w13u pioneer. All these are different markings on the unit. If you can get this at a junkyard, try to get the wiring harness pieces. That will save you some serious money! Here is the search I would recommend.. copy and paste this on ebay (t1819,t10004,pt546-00130) also pioneer (2011,2012,2013)
I got mine shipped for about $80. Be patient, and keep watching otherwise you can spend $200 or more.
First off, they have this fancy new style of antenna. So you need to convert this back to the old style. Find this on amazon. Scosche lsaarb
To get the wireless speakerphone to work, you have to buy a couple wiring harnesses:
pt546-00120-ch (this is a 20 to 28 pin adapter that allows you to plug in the mic.
pt546-74120mc (this is a prius mic)
To use the usb, you need the pt546-00120-us
On the usb cable, you have a couple options. You can cut this brand new cable and wire it to a female usb cable, or you can order a dash connection from a tacoma or tundra. p/n 86190-0c020. If you want to do that you will need a "a" to "A" usb cable. find that cable on amazon or your local computer shop.
