I sent an email to the seller and got the details below back. It does look like he has kept good track of the maintenance. Any thoughts on this????
Front axles have been done along with front wheel bearings. You will see a bill below for the front axes. 8/04. The front bearings were replaced 3/09. The front axle work is expensive, but should not have to be redone.
Yes, I have all maintenance records since I purchased. Here are details:
8/09: 217,000 miles - $155 - Replace EGR randucer.
6/09: 211,556 miles - $474 - 30K tune up, includes 6 spark plugs, intake cleaner, automatic transmission flush, antifreeze flush, clean brake area rotors and adjust emergency brake. Disc brakes were good and did not need replacing. Since the Land Cruiser is a heavy vehicle (6,600 lbs), it does go through a set of disc for the front about 35-45K. Depends on if you are highway miles or city. By the way, this Land Cruiser is equipmented with ABS brakes and all 4 disc. This was a option in 1994. I have never had any issues with the disc brakes.
5/09: $208,200 miles - $36, Land Cruiser's holds 8 quarts 10w/30. Brakes ok at this check up. I change my own oil from time to time. I change betwee 4,000-5,000 miles with new filter.
3/09: 203,343 miles - $600 - Replaced front bearings/seals, change oil, brake system flush.
1/09: 200,000 - $152 lnstalled new Toyota shocks. The FY80 series had truck shocks, not stuts. I have replaced 2 sets, one set when I purchased in 2005, and 2nd set at 80,000 more. I don't have labor invoice, but it was part of new tires installed (probably $50 for installation).
12/08: 198,625 - $674 Installed 4 Bridestone Dueler Revo AT tires. I have put on Michelen prior to this set. You will get 40,000 per set. Both times, no issues with alignment. I would however, replace my next set with a less aggressive tread. You get a little rougher ride from these AT tires. I would recommend Kumbo's. I have a set on one of my other vehicles, and they are great..and much cheaper than Michelin. Several of my friends have on trucks. Got to Kumbo web siste to see and Bridestone for the tread on the AT. Tire size is 275/70R16. Alignment performed at all tire changes $39.00.
8/08 179,971 miles - $430 Oil changes, front disc pads, new front rotor, R&R 4wd hubs and bearings.
6/08 184,621 miles - $96 Minor tune up, replaced plugs, oil change, brakes 1/2 worn out per Toyota, ok.
3/08 180,736 miles - $394 - Coolant flush, transmission flush, top engine clean, replaced A/C evap and recharged unit. By the way, this is cold air conditioner...I have never had any issues until this. AC part $22, labor $60. This was part of total bill for this visit of $394.
10/07 172,408 miles - $298 Install differential seal and transmission sensor, new power antenna, oil change, state inspection.
6/07 167,304 miles - $381 Install EGR vacuum value, and value assembly.
4/07 162,248 miles - $876 Install 4 Michelin tires LTX and alignment.
5/07 163,948 miles - $1,202 Replace front axle seals, replace disc barkes and resurface rotors, repalce transmission fluid seal from speedmeter sensor.
8/06 147,163 miles - $260 oil change, repair right rear window seal, repalce all fan and air cond belts,
10/05 127,508 miles - $444 Replaced starter
9/05 126,971 miles - $800 Install 4 new Michelin tires, rotation and installed new Toyota shocks.
9/05 126,266 miles - $214 Power steering flush per Toyota requirements. repaired exhaust shield, state inspection, oil change,
8/05 123,246 miles - Major tune up, oil change coolant flust, trans flush.
1/05 109,515 miles $730 ABS warning light, had to repalce rear disc and rotors, cylinder and front brakes.
8/04 96,990 $1,969 - This occured after I purchased the vehicle. Front axle seals, wiper kits and repack front bearing. Replaced both oxy sensors, minor tune up.
7/04 95,936 miles $470 - oil changes, transfer case oil change, automatic flush, coolant flush, spark plugs, top engine clean,
Thanks,
Eric
