NaterGator
On Gilligan's Island
Just gone done getting dinner tonight and on a whim I got out of the cruiser with it running...
At idle (without AC, didn't try it w/ AC) I'm hearing what I can only describe as a worrying noise. Here is my best attempt at describing it: most audible from the rear of the motor standing on the drivers side, it has a sort of indirect/muffled clanking-knocking quality to it. I got under the cruiser and it sounds :gulp: low and far back on the motor.
Other factors to consider: I'm still getting pinging on acceleration, temps are normal, a bit of coolant loss but the heater valve above the valve cover on the firewall is leaking a bit, still throwing P0401s, threw a P0420 and my ps floor is hot so I assume my cats are toast, original HG, my latest blackstone report shows absolutely nothing amiss
Here is the blackstone ~2,000 mi ago w/ 6,500 mi on the oil for reference:
I will try to grab a digicam and get a sound byte. From my last $2,500 escapade here I've learned not to ignore new noises... and right around this time last year my GMC had an oil delivery issue in the lower end and grenaded the motor while someone else was driving it, so needless to say I'm not keen on having that happen again one year later on a much finer (and way more expensive to fix) automobile.
Help?
Is it possible this is a leaky exhaust manifold at cyl 6?
Help?
