Revisited the Fourwheeler magazine article that converts an FJ60 to a 3FE.
This thought came up when reading the specs for each engine:
The 2F makes 135hp, 210 fp torque.
The 3FE makes 155hp, 220 fp torque.
The 2F compression ratio is 7.8-1
The 3FE compression ratio is 8.1-1
I wonder what the 2F would make if you raised the compression. Were it equal to the 3FE would the hp figures get closer? Be equal? What if you raised the compression to say 8.8? 9? Yeah, premium gas comes into play but. . . I wonder.
The 3FE FJ60 made 16 mpg I don't consider this to be a cost effective swap. They mentioned 'Cold stumbling starts are a thing of the past,' I've never had that problem with the 2F even with the choke not working.
They say the 3FE, 'the engine has never faltered or lacked for power,' neither has my 2F.
They say, 'Advantages of swapping a 3FE for a 2F include easy starting, a smooth-running engine, perhaps improved mileage, onboard diagnostics if a problem does occur,. . .Toyota dependability, and reliability,' my 2F, starts easy, runs smooth, gets 14 mpg, is de-smogged so my diagnostic computer (my human brain) works fine, and also exhibits Toyota dependability and reliability. Not cost effective I say.
A question: Does raising the compression ratio positively affect performance at high altitiude (>7000') all else being equal?
