[FONT="]I was up having a little bit of fun this last weekend when my cruiser started acting up. Misfiring like crazy, no power and a few backfires that scared the begeezus out of my two friends and I (and a few rafters). Long story short, I managed to limp it about halfway home down the canyon when she backfired one last time and totally died. 26-mile tow bill later we were back home with my Cruiser in the garage trying to figure out what the hell was wrong.
My friend and I pulled out the carb (Weber 38) and completely tore it down and cleaned everything out. Nada, still would not start and it's getting plenty of gas.
Tested for spark, no spark. Tested the coil for correct resistance, coils was bad, replaced the coil, still no spark.
Popped the cap off the rotor and found the issue:
So I'm not sure if the o-ring went bad or what but there has definitely been water getting in there for a while now and when I pulled it off, there was still water on the inside of the cap and pooled in the distributor. Oh and did I mention that until I started searching around on here I had no idea there was supposed to be a vacuum line on the cap to vent it? Previous owner didn't bother to hook that up when he put in the Weber.
So here's my question: Should I try to pull this one and clean it up, replace bad parts, etc... or just get a rebuilt unit from NAPA or MAF or somewhere else?
I'm not overly familiar with this older style of distributor and the prices I've been seeing look like it's almost as expensive to buy the replacement parts for the stuff covered in corrosion as it would be to just buy a rebuilt unit. Let me know what you all think!
[/FONT]
[/FONT]
