What are your impressions of the Aussie Locker? Anyone had one in for a long time? Any parts apparently worn out faster because of the Aussie?
My experience:
I've had my Aussie Rear Locker for about 3,000 miles. It is awesome to have a locker off-road and for $250 you can't beat the price. I have been able to go through a couple muddy wide stream crossings with the locker that I got stuck in before. Before I got it, I was mainly concerned about its on-road manners. It is actually fairly easy to get used to. The ratcheting around corners is quiet and kind of a cool noise. I don't hear it if the windows are rolled up or if I have the radio on. I've only had it really thunk once. Since I live in California, I have to make a lot of U-turns. Those are very easy to do with the Aussie. I can also shift from 1st to 2nd around a corner without the locker doing anything funky.
If I don't accelerate or decelerate smoothly, then it can get a little hurky-jerky. But you just put in the clutch and it goes away. Nothing dangerous just a little annoying. You also have to attend to your tire pressure. They really have to be equal otherwise it will pull one way. Also, right now my engine runs a little rough when it is cold, so when I shift into 2nd while accelerating when the engine is cold, it pulls to the side a little.
My main concern is long term stress on the driveline. Since it is always locked there is feedback up the driveline from the locker. After about a 1,000 miles, there is a weird whirring sound from somewhere in the driveline. Apparently, the sound isn't bad since I'm about the only one that can really hear it. I haven't been able to locate it yet. It may not be related to the Aussie, but there does seem to be added strain on the driveline because the locker is always locked. I don't have any proof just an impression.
At some point in the future, when I have the money, I'll probably replace it with a selectable ARB locker. Although, the Aussie is reassuring because there are no pneumatic lines (or cables, electronic motors, or hydraulic lines) to break.
P.S. I have limited wrenching experience and the Aussie is easy to install by yourself.
My experience:
