I'm in the process of getting my ducks in a row for my first axle service. I've been hitting up the threads, youtube, and have some service manuals on order.
I'm doing my best to make sure everything is ordered correctly to minimize my downtime. The one variation to this process is the fact that I'm doing a diff swap at the same time as my axle service.
The PO (2manycruisers) swapped the rear from a 4.11 to a 3.73 diff for highway cruising but didn't get around to swapping the front so it's first on my to-do list.
My questions are:
1) Where in the sequence should the diff swap take place? Before or after axle removal?
2) What other items should I consider servicing or upgrading during this process?
3) Should I be aware of any surprises with this being an Aussie HJ45 with disc brakes of unknown origin?
Here are some pics I took last night for reference.
Also, here is an email from 2manycruisers with his input:
I appreciate any input you might have to add to my research
-Kevin
My questions are:
Hi Kevin, The axle itself is definitely 40 series. The brakes could be 45/47 or 60 series. Apparently both had the air vents in the Aussie market. All the knuckle parts would be the same, either way. Things that vary: bolt pattern of the trunion bearing caps/steering arms changed in '79 to a larger pattern. I think all the Aussie ones would have the larger pattern because they didn't have disk brakes before '79 like we did. Similarly, the Birfield grew in '79, so these should be the larger ones too. The length of the birfield (the outer axle and CV joint) changed, also I think in '79. If there is a snapring or retaining bolt in the end of the axle when you pull the lockout hub flange off, you have whichever length is correct for the Aisin hubs. That probably is not an issue on the Aussie ones, as here many came with drive flanges on the front axle and were changed to Warn hubs. Those have a different length Birfield. If the disk brakes were swapped from another axle from the knuckles out, rather than the entire axle, you may have some combination of the different years of parts, but I don't know how it was done.
What I would do: I would confirm you have the larger knuckle pattern, probably by searching on Mud. I think they have larger studs and 19mm nuts, which would also confirm. Order a knuckle rebuild kit for '79-up if you have the larger pattern--the only difference in the kits is the proper shims for the steering arm bolt pattern. I have ordered from Marlin Crawler in the past. He uses good parts and I like him. They also make a heavy duty inner axle seal that I would order with the kit (1 seal per side). Up to you whether to buy new wheel bearings at the same time or just repack yours. I didn't hear or feel anything up there, but might think about replacing them just so you know what's in there. Same with the brakes--I don't know if the rotors have enough to be turned or not. If you can check that before you order, you could make the decision. I would also consider rebuilding or replacing the calipers. I haven't priced them, but if they are reasonable from Autozone or someplace like that, I'd order some for a V6 truck to get the bigger pistons (a little research here, as I haven't actually done it before). And since the rotors are heavy, if you can get them from a local autoparts store for a decent price, it might be better than shipping. Front axle service is a chore of a job and you don't want to have to tear into it again any sooner than you have to, so I would encourage you to replace anything you have any question or concern about to save doing it again later.
Also, when you rebuild, there are shims under both the trunion bearing cap on the bottom of the knuckle and the steering arm on top. There is a fancy tool for determining the exact center of the knuckle for birfield alignment. I don't think it requires that much precision. I would use the same shims on the bottom trunion bearing as what you find when you remove it then shim the steering arm to get proper preload on the bearings (you can use a fish scale for this, Marlin sells one I think). Also, the Marlin Crawler inner axle seal is designed to maintain a good seal with a higher level of deflection, giving a little more room for error on centering the knuckle.
-Kevin
