I picked up a 1974 FJ45 last week. Total basket case that I got for parts but the more time I spend on her the more I think she deserves another chance.
I'm trying to get the engine running enough just to see what sort of shape it is in. It has had a 2F swap: engine #383XXX which I think makes it a mid to late '79 and looks to be the original AISIN carby for this engine. The truck has been sitting for some time.
So far, I can get it to fire for a second or two and then it dies. When it fires it is revving high. This is with the choke on, no air cleaner, no exhaust after the manifold (broken stud
correct thread tap on order...) Sounds awesome!
Wiring is a total hack from PO. Starter is touching two wires together, ignition is a toggle switch on the dash. I have replaced spark plugs and leads. It fires, so I know I have spark.
Fuel pump works. Fuel is in the sight glass on the carby but nearly all the way to the top of the window. There is a dot in the middle of the window, so I assume this is supposed to be the correct level???
I'm thinking the carby is to blame. What would cause the high revving? Linkages all seem to be where they should and working correctly. Carby needs a good clean and a rebuild is inevitable I suppose.
Thoughts? Just looking for a little input on where to go next with this.
