I recently replaced the radiator with a heavy duty 4 core unit from www.radiatorbarn.com. Before I did, though, the old one sprang a major leak (long story) and I overheated the engine before I could get the rig to the shop.
There's no "chocolate milk" in the oil, but now the radiator overflow bottle is consistently boiling over. I ran the engine with the radiator cap off and can see bubbles coming up periodically. At idle, everything appears okay, but when I drive and put a load on it (up a hill) and pull over and open the hood, the overflow bottle is, well, overflowing. The engine temps are not getting above the first hash mark though.
I've also noticed that when I shut the truck down, there's a small amount of antifreeze running down the bellhousing and dripping on the exhaust pipe (located because of the "hissing" when the liquid hit the hot pipe). Could this be a bad freeze plug?
The engine runs and idles fine and I don't see white smoke coming out the tailpipe or smell antifreeze in the exhaust. Still, I'm thinking head gasket failure (especially with the recent overheating episode), but could there be any other explanation?
Tomorrow, I'll take the truck in for a compression test. I'll post up the numbers when I have them.
