orangefj45
Supporting Vendor
i was approached by a customer and fellow mudder to build a stout h55f combo for an fj40 conversion. we settled on a ew trans from the dealer since pretty much all the used transmissions out there have a ton of miles on them and everything i've seen that's hit these shores from oz has been worked hard and put away wet; including my 81 troopie. my 84 troopie seems to be the exception to that rule but that's a different story all-together.
anyways, along with the new h55f we decided on the split case from an fj62. we did so for a few reasons:
1) large idler shaft
2) bearing supported high and low speed gears on the main shaft
3) availability
part of the build was also to include some sort of parking brake. the kit from sor isn't cheap and replacement parts can be tough to come by. besides, the drum style ebrake setups just don't seem to have enouigh holding power. so we choose the disc brake kit manufactured by TSM. i have been using their components for doing rear disc brake conversions for years and the quality and service has always been excellent. this time was no different.
last but not least, my customer wanted to run a set of twin-stick shifters for the split case. nobody sells a kit but i had built a few one-off sets in the past so i decided to build my own set again, but this time with the thought in mind that i would keep in mind that i want to sell this in kit for in the very near future if there's enough interest.
well, i got the powertrain pretty much done today, just need to button up a few loose ends and it'll be off to it's new home. more detailed shots to come later this week........
georg @ valley hybrids
3) availability
