- Thread starter
- #21
the output shaft splines for the a440f, h55f and h42s ( in fj60s ) is 18 spline so the cases interchange without mods. you have to add the 5th gear oil funnel and on the early cases you have to plug one of the bolt holes; it's right below the main shaft. that way the two units can't swap fluids.
this combo will bolt right into an fj40 with some tunnel mods. the rear drive shaft has to be shortened but you do not have to move the rear axle back.
