- Joined
- Aug 15, 2005
- Threads
- 776
- Messages
- 5,125
NEw issue . . .
(73 fj40 with 60 series steering and new 60 series axle plus flipped springs and new shackle bushings steering is very tight and nothing is loose. It has all been replaced.)
I have a 4" lift and 1" over shackles and was getting some wobble after wheeling. The steering has always been quirky and I needed to keep it adjusted just right or it would get wobble.
I figured I needed caster shims and most posts said 4* shims should be perfect.
SO I installed 4* shims and my low speed vibration whet away and I was really happy until I hit 45 mphs. Death wobble. I checked my toe and it was at 1/8". Decided to check caster by putting my angle finder on the bottom of the knuckle on a flat spot before the lower knuckle bolts. My angle finder showed looking at the back of the driver side wheel, plus 8* (angle was towards the front of the rig).
Even with 35" tires, this seems way too much. Shouldn’t I be closer to 3 or 4*?
I think I need to take them out. Comments?
I took out the 1” shackles and replaced them with the stock ones late last night and I wasn’t able to check to see if that was the problem.
What about the flipped springs? Could the 4" flipped springs be the problem?
