Greetings,
I thought I would share some of my experiences with the group in regards to doing a U-bolt flip on a spring under FJ-40 with the GM U-bolt plates. When I saw this thread I knew I wanted to try and do this. I really couldn't find a lot of info. other than, "it's easy" or "Three will bolt directly on, one will need some modifcation (PS front). " That may be true for an FJ-55, but it wasn't true for my '71 FJ-40. For those who do not know, I am referring to GM Plates> GMPartsDirect.com. Part # is 15592588 ($65.00 for all 4 after shipping).
The first thing I noticed when my arrived was that the spacing was incorrect for my leaf springs. The holes on the GM plates were 2 5/8" on center and my leaf-springs were 2 3/4" wide.
So much for a direct bolt on. To correct this, I had to weld up the holes, then re-drill them on the correct spacing. Let me tell you that is easier said than done.
I am not a a person who has worked with steel alot, so I had to go and buy a 5/8" drill bit ($20.00), and then go and buy a drill bit sharpening tool ($40.00) to fix the drill bit that I messed up because I didn't know I should put oil on it as I drill it to keep it cool.
OK, so next comes the U-bolts themselves. By my measurements, I need 6 SQUARE u-bolts 8" long, and 2 SQUARE u-bolts 9" long. These total $107 with shipping I believe. That brings the total to $172 plus the $60 I spent on tools
. My cost got alot closer to the $300 that it costs to buy these pre-made from one of the Cruiser outlets online, but hey, wheres the fun in that
Now I needed to make the bottom plate to keep the u-bolts from going anywhere. I started off with a piece of 1/8" flat steel, cut slightly wider than my leaf springs, and about 2 inchs longer than the gm plates.I then welded more steel on the ends to create a place where the u-bolt would sit. It's hard to describe, but a pic says it all,
I then used the origional plate and cut out the center section and welded it into the center of my new plate;
here is the plate ready for paint;
The next step was to bolt it up.
The driver's side was easy.
Pic from the top;
and a pic from underneath;
Yeah, I know, I need to paint under there...I'm getting there
The driver's side was a bit harder. I had to weld in a spacer to raise the GM plate up on one side due to the short side housing. I also reinforced the inner part of the plate because I gound off quite a bit of the plate trying to get it to align corectly. Others have not had to do this, and I suspect it may be due to skinnier leaf springs...not sure. I did it for piece of mind.
I haven't gotten to the rear yet, but it should be just like the driver's side front. I also decided to only weld up one side of the 5/8" holes and re-drill, using the origional holes on the other side and just offset the alignment by 1/16". I am sure I have left some things out, and my welding skills suck, but I am getting better.
Feel free to ask questions, give pointers, flame me, whatever, I can take it
? Now I needed to make the bottom plate to keep the u-bolts from going anywhere. I started off with a piece of 1/8" flat steel, cut slightly wider than my leaf springs, and about 2 inchs longer than the gm plates.I then welded more steel on the ends to create a place where the u-bolt would sit. It's hard to describe, but a pic says it all,
Pic from the top;
