- Joined
- Sep 7, 2004
- Threads
- 512
- Messages
- 2,158
Okay I have to say I like POR 15 and have used it before but the price is the killer when a quart of Zero Rust AR-62 BLACK is $24.00 vs $50 on the POR 15.
So with that said I am willing to try it out but need some info from you folks that have use this product before.
What I and wanting to do is paint my-bear metal FJ45 steel cab roof (inside and out) with Zero Rust. The roof has some small spots of rust that had been blasted but I want to stop any rust from re-forming especially in the rain gutter area.
Then I want to paint the top epoxy white.
Question's:
Is Zero Rust considered a Paint or a Primer that can be painted?
If I use a quart can, can I brush it on instead of spray it on. The POR 15 can be brushed on and will flow to a smooth flat finish when dry, will Zero Rust do this?
Would the aerosol can be a better way to go for the size of the item to be painted?
When dry, what kind of top cote is to be applied or can a self etching primer be used before painting white or ? This is my biggest question.
Of course I want a nice smooth finish when done, but as stated I also want to fight off any possibilities of rust coming back. I also am planing on doing the inner LWB wheel wells and front inner fenders in the same manner but without applying any other paints, just Zero Rust.
Any info is welcome. Thanks in advance.
Question's:
