I looked at the motor today as it was vibrating and could easily see that the york (even though not pumping air) was vibrating badly.
So I got out my wire clippers and cut the Korean Belt off of the unit.
No more vibration.
So, . . . now I'm gonna try one of the belts that isn't so short.
I completely disassembled the flywheel to clean the York after I got it. So perhaps I didn't put it back together correctly?
Didn't seem like a lot of room for error ~ everything was pressed together.
Any thoughts?
Did you use the belt that came with the kit or the NAPA one suggested by TrickyT (Napa XL 25-7375 - 10mm x 967mm)? I used the NAPA belt and found that it was still pretty tight, so maybe an extra 10-20mm would be better.
Napa p/n XL 25-7380 is the next size up belt, 10mm wide x 980mm. But note that my belt stretched after I used the compressor a few times, so what's tight initially may not stay that way.
Can you still get these brackets? I would love to have OBA on my truck. It's so convenient.
Sweet. I found my christmas present.No need to mess with a york to have OBA. https://forum.ih8mud.com/camping-outdoor-gear/166969-puma-12v-compressor.html
I built a bracket for my York in about 3 hours one Saturday and set it up to run of a long AC belt. No need for extra tensioners or special water pump pulleys. Its also nice and close to the motor to allow lots of room between it and my 2nd battery box.
Airing up tires is a treat now at idle it takes about 40sec to air up my 315's from 15psi to 40psi.
Do you have any photo's of your set up and bracket? If I could add it and just change the pulley on the york and get a longer belt that would be awesome. I also might just buy my buddies Viair compressors that he pulled off a mini truck that had air bags.
does it have to be a york? Can't I just pull any AC compressor from a junk yard and work it that? Don't they all basically work the same? If so I'll just get any AC Compressor I can find and get a plate fabricated. As far a lubrication is concerned I could just fill it with oil and cap it off couldn't I?
The biggest reason to use a York has to do with lubrication. Most compressors use the freon in the A/C system for lubrication. The York, on the other hand, has a separate oil reservoir and is fully lubricated by the connecting rods splashing oil all around. Plus they put out a bunch of air.
sorry for the silly question.
has anyone install a york in to the hj80 4.2 diesels.
