- Thread starter
- #241
A u-joint would work fine. But, you're adding money needlessly IMO. Have you welded in the steering box mount yet? If not, just put it at the correct angle and tack it in. No need to shim the box itself.
Everything else is looking great! Nice to see some progress! I take it you made it home for a couple of days?
Yah..the box mount has to be bolted in like the motor mounts because the frame is powdercoated. There's more to it as well..if I change the angle of the box or the box mount, I start to touch things like the motor and the over inject stop...as I told Wayne, I don't have a ton of fabricating tools or talent. I have to do bolt on stuff..I'm pretty good at figuring stuff out if I think about it long enough...the double u-joint is the simplest and easiest fix for me.
I'll have to shorten the drag link as well...my local machine shop can cut and sleeve it for me easy enough.
This is y third week at home, but only 3 good days working on the rig..a couple more days this weekend, but then I travel most of May...
I'll post some more pics this weekend.
