You can see in his photos that the pin in his distributor is hollow, so no need to wonder about other people's distributors.
(EDIT: Snap another pic of the gear if you want... with no lint or debris so we can see it bettter. From what I can see here, I would reuse it with no worries.)
The end of the dist shaft me have already been damaged or eroded from moisture in the past. The gear coming loose will not damage the end of the shaft.
The simplest way to quickly get a pin that is a snug but easily installed press fit would be to find a drill bit that is the right size. drill bits come in am amazing variety of sizes. You might not find the exact sixe at Lowes though. But it is worth checking. You might find some round rod stock that will fit too. Take the dist and gear with you and see what fits.
If you can't find any, or if the hole in the gear has been damaged by the failure, you could find a pieces of round rod that is slightly larger and drill the holes in the gear and shaft out for a snug fit.
One advantage of using rod stock is that you can peen the ends over to lock it in place. If you use a drill bit it will be harder and not peen easily. if you do not have a snug interference fit it might be harder to be sure the harder pin you wind up with is securely locked in place.
Drill bit would likely resist shear better, but any solid pin should be plenty strong.
If you have a welder, a small spot weld on one end of the pin, to the gear would also lock it in place.
Do also make sure that the dist spins freely before you go to the effort of repairing it.
Mark...
Mark...
s for all
