Most firestone places use autozone for their parts. being I used to work for them I know those pins are s***ty.
Replace the pin yourself if need be
Might just be the pic, but that cam gear doesn't look too good to me.
Sweet got it off...just needed to use my big boy muscles...do I need to replace the whole gasket or just scrape the sealant off the oil pan and shove it back on?
The teeth on the cam gear look like they're deformed or badly worn. They should look a lot like the teeth on the dizzy gear in shape and surface finish (minus the odd burrs).Why, what do you see (or think you see)?
Also this is what a stock gear should look like. Those are some s***ty pins you have in that dizzy. Certainly look thin. I'd be going back to firestone and get my original dizzy.
I know a good Cruiser shop in Englewood. You've probably heard of them .. Rocky Mt Cruisers. They have done some work for me. Give Steven a call and ask him if he has ever seen this. I had some bad experiences with Firestone in the past not on my rig but with another vehicle. I would try to find someone that know's more about Cruiser's if I were you.Are the folks at Firestone installing them wrong or something?
I had the ignition coil go bad and replaced the dizzy. A couple weeks later it broke the shear pin (messing up the timing so it would only idle at like 500RPM) and they replaced it under warranty.
Today, it broke again (I was going down hwy and it lost power...I coasted to side of road and it died and wouldn't restart...and I got to walk home 2 miles (uphill in the rain...really!!) since I forgot my cell phone.
Any way, the guys at Firestone said they didn't see anything wrong with what they could see of cam and they said the oil pump was functioning normally.
So, what's grenading my distributors...something internal to the engine?
I don't want to stuff a crate V8 in this beeotch, but I might have to....I guess I'll hold on to my 89 pickup for awhile!
Here's my awesome picture of the day...glad I pay that $1 a month for towing coverage...
Busted tip of the oil pump shaft? That could definitely have jammed things up.
I have never seen this. Hard to figure how it would have broken.
Did you take the pump apart? How did it look inside?
Mark...
This crap remanufactured dizzy (of course) doesn't have the o-ring. What should you use to seal it up from water?
I'd use a used good stock dizzy to seal it up. And I wouldn't worry about opening up the oil pump your planning on replacing with a new stock unit.
Do me a favor are there any hammer mark on the sides or top of the dizzy. Like where the rotor button resides. Sounds like they couldn't get it to seat so they hammered it in. Did you ask them to replace the dizzy or did they?
whats the diameter? Autozone along with a few others does sell dizzy o-rings in their help isle.
ass figured it out... That really frustrates me
Wow, I finally figured out how to multi-quote....thank you Rogue Chocolate Stout!!!
Cool, I'll check that out. Non-OEM stuff sucks!
I didn't see any hammer marks. They replaced the dizzy (told me it was bad along with the ignition coil). They replaced dizzy 2nd time under warranty.
I've pm'd cruiserdan for a new oil pump & gasket...what do those run?
I'm taking my distributor and oil pump by Firestone tomorrow to ask their "ASE technician" why he didn't drop the oil pan and check the oil pump after the first distributor he installed broke the same exact way. Seems like an "expert" might know to check that. I mean, my dumb 1ass figured it out... That really frustrates me
ASE certification and 65 cents will get you a doughnut.
Mark...
