The transmission is in....but I wouldn't wish that on my worst enemy. The turned flywheel went on easily, the clutch assembly, thanks to the installation tool was a breeze. The bellhousing a bit more difficult given the awkward location of the bolts. But what a f-ing nightmare getting that tranny back in. The stand never failed me really, in so far as I wasn't killed by a falling drivetrain, but it took me about 3 hours of proping, prying, pushing, pulling, turning, swearing...before it finally lined up and slid in. I slowly got the four bolts started and knew I was lined up right, then turned the t-case output shaft a little bit and in she went....I ratcheted like I've never ratcheted before...praying that I'd get those bolts tight before I woke up from the dream.
Now I still have a question, how do you know what the proper pre-load is on the t-case output nut? I swapped out the seal and need to know how tight.
Also, does anyone have an exploded diagram of the t-case output flange? I can't remember if the spacer ring went on the inside or outside of the speedo worm gear..s***...for that matter, which way does the drive gear go on or does it matter?.
Also, a comment on Napa Auto Parts Duncan...run...do not walk...away from these clowns...5 parts ordered, 3 were wrong and 1 never showed up at all. I'm now waiting until Tuesday to get a slave cylinder.
