JunkCrzr89
Competent Ignoramoose
30mm32mm socket if I remember . . .
All I'm going to point out is that the bushings are now 22+ years old if they are the OEM ones installed during the manufacture of the rig.
That alone should tell you something and guide your decision.
The bushings are a pain to remove/replace, and to me, my time was worth more than the cost of replacement control arms, but if you choose to replace the bushings, I'd look at Cruiser Outfitters site:So, what bushings do you recommend?
Ah, I thought he was talking about sway bar links / cushions.The bushings are a pain to remove/replace, and to me, my time was worth more than the cost of replacement control arms, but if you choose to replace the bushings, I'd look at Cruiser Outfitters site:
Cruiser Teq | Powered by Cruiser Outfitters
Cruiser Teq is powered by Cruiser Outfitters. Get high quality OEM and aftermarket Land Cruiser parts direct to your door, fast!cruiserteq.com
Instead of spending my time typing my experience in, here is someone else's post that duplicates my experience:Mine are visibly just worn as can be. And this fits with all my symptoms and the alignment guys said they are bad.
is just doing the bushings that difficult? If I rent the press machine it go by and use someone’s? It is quite a savings.
As for buying Toyota, I don’t think I’m going to have the vehicle more than another 20 or 30 thousand miles. So I think the aftermarket will work.
Ok thank you. Are there any actor market arms you recommend that aren’t the insane beefy ones from Slee? I’m ok with cheap![]()
Ok, the Rear control arm bushings are shot? Not sway bar links? (Sway bar links easy to replace).Ok, thank you all the issue is identified. When I had the wheels aligned we looked and it’s sure the 4 link bars in the rear. The bushings are totally worn.
would these be good?
x2. I hated every minute of replacing the front control arm bushings, so much so that I just bought new arms for the rear.The bushings are a pain to remove/replace, and to me, my time was worth more than the cost of replacement control arms
If it's just your rear lower control arms, SPC LCAs get decent reviews and are a good bit cheaper than OEM (and much easier than replacing the bushings).Ok thank you. Are there any actor market arms you recommend that aren’t the insane beefy ones from Slee? I’m ok with cheap![]()
