Hello,
I recently acquired a 1983 fj60 and have been working through a few little problems it has. One of which is the ignition, which doesn’t entirely work. To start the vehicle, you have to turn the key to the start position and then there is a button wired up to the starter relay to run the starter. When you turn the key you can hear the solenoid click but the starter doesn’t turn. If I look under the hood the button is wired up directly to the posts on the starter relay. How can I wire this up to remove the button? I want to just use the ignition cylinder to start.
