Wire color code
Out of curiosity. What are you planning to do
Why not just put a switch on the wire to the switch on the brake pedal? It's a much simpler switch, easy to get to, and the car won't start if the brake switch circuit is not complete.
HTH
Hi gaijin, I have check to brake wires and there are 4 wires with the connector which wire should I make the cut. By the way tnx got the infos.
I'm sorry, I don't know. But if you can find the one that is hot (conducting current) when the pedal is depressed, that's the one on which I would install the switch.
HTH
While I don't recommend cutting any wires in your vehicle without the necessary skills, knowledge and first verifying their function with a quality DMM, maybe this will help. Obviously I assume no responsibility for the accuracy of this information, yada, yada... :D
