Changed it for him.why does your ad say “for sale” is a bit misleading I think.
Any photos please? I have a 1966 FJ40 and would like to seeI have a couple off of a 64. Not sure if they are the same.
Fishing in BC until Thursday. Will post when I get back.Any photos please? I have a 1966 FJ40 and would like to see
@hyhpe
Paul I do have a ‘63 SWB FHT and all 3 of the wiper motors I have are exactly the same so that would make sense. But I don’t have a LWB RHT (here) or a SWB RHT so I can’t speak to that.
That’s about 1.50 worth’s.Since my name came up here: there are two different early wiper motors--you can see the part numbers above. Although visually similar, the interior articulating eccentric arms are different and not interchangeable, and the motors park the wiper arms differently. With the anti-rotation bracket/arm situated at the bottom of the unit, Model 85110-60030 parks the wiper arm to the Right on the windshield as seen from inside the vehicle; 85110-60010 parks the arm to the Left. Ostensibly this was done to keep wiper arms from being directly in the driver's line of sight when not operating.
How the motors are mounted may be up for discussion: whether the anti-rotation arm is to sit at the bottom (as I believe), or the top of the unit, and whether the bulk of the unit hangs down below the windshield frame or above it. In any event, the existence of two different models indicates thought and design over just where the wiper arms are to be parked.
Since many years and many owners have come and gone, the thin aluminum motor covers can be flipped, as well as mounting either motor model "upside" down since the windshield frames have captive nuts for either RHD or LHD anti-rotation bracket/arm mounting. Windshield frames can be swapped with another, with wiring coming up on either side. Even personal choice could dictate one-of-each model, parked to both of the outside edges of the windshield. And model availability at a parts dealer may make the replacement choice for a buyer.
Did Toyota simply use whatever model was at hand during assembly (probably not), or did they calculate placement to satisfy regulations in individual countries? Were there ever changes at the docks, the distributors, or individual dealers, and what were the reasons? Lots of reasons why your Land Cruiser has the wiper motors it does. Be grateful that they work and even more grateful that they park when and where you want them !
My 2 cents.
Your wiper motor in the first picture is different than the motor in the windshield frame. Seems to me the first motor would sit higher. IDK.@Bear thank you for taking the time to respond and share your knowledge!
Interesting…this is what I have on the passenger side.
And to clear things up my driver side motor from above isn’t securely fastened to the windshield frame. However I do believe it is aligned/mounted properly (almost). If you zoom in on the parts catalog picture it shows the electrical connections coming off the same side as in my photo??? Also the majority of the motor body is hidden behind/below the top edge of the window frame. But….?????
I think the upside-down TNK motors could have been a 1961/1962, maybe stretched into early 63 thing.Looking back at this 4 year old thread, it appears that the wiper motor shown in the 3rd and 4th photos in Post #9 above is the incorrect motor for that windshield frame, and that it has been mounted upside down. It is part no. 85110-60010 intended for RHD trucks. The correct motor should be 85110-60030 which was supplied on LHD trucks as delivered to the USA. That is an early LHD windshield frame that does not have the two captive nuts--one on each side of the thru-spindle hole-- that allows either the LHD motor or the RHD motor to be installed. Later windshield frames come with both captive nuts.
HTH
