is the wiper arms on the fj60 compatible with other same era toyotas? be much easier to go to the junk yard and find one because im having a hard time
What year/model landcruiser do you have?Did you get any answers on your question? I would like to replace my wiper arms for arms with a more modern hook on the end. Wipers for arms with a straight end (as our Landcruisers have) are much harder to find so......
Huh. Must be an interesting story how a 1990 FJ62 USA model ended up in the Netherlands...Mine is a 1990 FJ62 (USA). I know what you mean, but once you figured it out it isn't that hard to do.
Wipers with the straight connection are less and less available, so I will have to 'convert'![]()
Gregnash, just this week I fixed the same problem you are having...not getting full contact with the rubber hitting the windshield. This is on my 60 with stock blades and rubber inserts that you slip into place.
It sounds draconian but it's not really. Remove the blades, put into a vise and bend to better fit your windshield.
A) note where the rubber is not touching the window
B) remove the 2 screws, remove that part of the arm, then slip the rubber out
C) take the metal part that you removed the rubber from to your vice and GENTLY bend it at the appropriate place. I had to slightly bend both ends.
D) the part you are taking to the vice and bending, is the part that the rubber slips into, not the main arm which stays on the windshield.
I had to go back to the truck for multiple 'test fits', but in short order it solved the issue with full contact...rubber to windshield.
John
