Surprisingly enough, my bushings are in good shape, but after reading all the BS in this thread, I'm tempted to order some just 'cause!
This may be over kill…excellent greaseTo bring it back around to the original subject matter; Joey do you have any inclination or plans to reproduce the other bushings in the linkage? It seems that if those and the rubber boots can be replaced, the linkage would have a complete refurb available once OEM supply of new linkages runs out.
Also regardless of that, do you agree with using white lithium grease, or would something silicon based be better for long term lubrication on plastic and delrin parts?
I have yet to install your bushing I ordered from you, but if my other bushings are trashed (hopefully not since I've had the TT clips in place for over 10 years) I'll have to just put in my new linkage, which I'll still use your bushing since I think the delrin is a considerable upgrade wear-wise over the original plastic.
Or at least parts in serviceable condition. That's what I'm wondering here, since Joey's part is delrin, and the OEM parts are most likely a type of nylon, which grease would be the optimal for long term use on a delrin/nylon/plastic part that moves against a metal surface.Grease is great but without new parts just a temporary fix. Mike
I have one too. Glad I do because I had to take a couple rubber boots from it. I could've just installed the whole new assembly but I really wanted to experiment with cleanup and lube of my factory linkage, installing Joey's bushing, and see how well a refurb works (and lasts) because these parts won't be around forever. I did notice on my new linkage that though the joints are very free moving, there is no slop (and surprisingly no slop in my old stuff either after 33 years).FWIW, 'Super Lube' is PTFE grease for $4 a tube.
Joey is right: I have a NOS wiper linkage and it's not tight at the joints, probably designed that way.
It's the OEM factory arm. I DID get one of the first bushings Joey produced, so I'm wondering if the current ones have been refined since then.Could your wiper arm have been changed at some point, or is that the OEM arm? I just installed this bushing and it fit easily into the arm. The hard part was getting the motor to snap into the bushing opening, but with a little heat and some grease it popped right in.
Okay so it'll looks like I did it right, then. Strange it's so tight on mine. I'll give it some time and see if it loosens up with use. Worst case is I put the new linkage set in and run it for another 33 years lol.Yes, exactly the same, then had to push ball end of motor arm into the bushing.
