Harmonic balancer failure on my 87 60, 2F. Worked all afternoon yesterday trying to get the pulley off, and up until now searching the forum without finding anything. My pulley will not come off. I can pull it forward to the position in the photo but then it feels (and sounds) like it is hitting something metal. I tried a puller...won't budge. Blaster, tapped with hammer all around and back of pulley. Tried puller again...nothing. All I managed to to was bend the plate where the harmonic balancer was attached and I didn't want to completely screw something up so I stopped. What am I doing wrong? Any suggestions? Btw...the nut was easy to get off. Put the transmission in 4th, used a long breaker bar and 46mm socket...no problem. The snout on my crankshaft looks okay to me unless I am missing something or can't see enough of it yet, so I am hoping I dodged a bullet there. Planning on changing timing cover gasket and crank seal if I ever get in there. Replacement pulley and HB (used) on order. Thanks in advance!
