Is the OEM Toyota head gasket an MLS gasket?
Is the Cometic the generally recommended head gasket over OEM cause it’s MLS? The head is getting resurfaced and a valve job.No, but the Cometic one is.
Opinions differ. If you're going to boost, seems like consensus is to do the Cometic. If you do an MLS gasket, you have to get the block decked to make sure it is absolutely flat (and get rid of old gasket pitting). Also have to make sure the head is absolutely flat.Is the Cometic the generally recommended head gasket over OEM cause it’s MLS? The head is getting resurfaced and a valve job.
Don't get too excited with this approach. Both 80's i own show up as 2WD on the Toyota website and neither shows any maintenance even though i have all the dealer receipts...If you want to know more about your trucks history, go to Toyota.com, sign up, and register your VIN and you will see the original build specs for your rig as well as most of the services performed at the dealership.
If you're not going to go that route, you should do the OE gasket. I am using the OE gasket. I cleaned the block surface and had the head checked for flatness at a machine shop.
Anyone know if the Lexus owner online group is more helpful than this one? I've heard it may show maintenance that doesn't show up on Carfax.Don't get too excited with this approach. Both 80's i own show up as 2WD on the Toyota website and neither shows any maintenance even though i have all the dealer receipts...
yeah. Block is not pulled. No plans for boost unless I do a rebuild and somehow come into about 10k. I’m sticking with OEM.
Best of luck. Lots of good threads and OTRAMM's videos on how to do it.
The issue I'm having is that I would absolutely love to do it myself... if I had the time. I'm not someone that would be able to just do the head gasket without wanting to do EVERYTHING I can while in there. I just don't have time to do that. If I did I probably would have started the project awhile ago. So I'm stuck in this position where I put off the head gasket as preventative maintenance until I have the time to do it myself (which may be a very long time from now), go ahead and pay someone else to do it now, or just wait until it fails and I'm forced to do so. I'm also very paranoid and have a hard time convincing myself to give my truck to someone else to do it when I know I could do it myself and know exactly what and how everything was done... which leads to me just putting it off longer.What size lift do I need to fit 35’s?
Seriously though, only you can answer the question as it’s based on your own tolerance. You can do it yourself for under $2k. The popular cruiser shop in Atlanta wants something north of $8k to do it for you last I heard, don’t quote me on that.
Mine went at 225 about 45 minutes from home. It wasn’t a big deal to limp it home but it wasn’t fun either. I was in the camp of people talk too much about hg’s on mud but I get it now. There’s an active thread here now about a guy who had his throttle body and upper intake off and the consensus was to go ahead and do the HG. Couple more hours and the head was off. It’s not a tough job.
Do it if you want. Don’t if you don’t. There’s your answer.
Owing to the mileage, uncertainty of present head gasket (original or not) and the possibility of become stranded far from home, yes....I would recommend replacing it.
Mine (1997 model) went 316K miles on the original. Might have gone further except I think I pushed it over the edge when doing an engine flush. So I wasn't actually driving mine when it failed. However it failed in a spot that so many do (number 6 cylinder) so that rather suggests it was on the cusp anyway.
If you plan to keep and enjoy the vehicle for a long time....it might not be a bad thing to consider.
pretty much what I was going to write. The #6 cylinder, yes, that's the area where most of our trucks tend to lose HG sealing. This happens when the truck overheats. Invest in a new radiator, hoses, quality coolant, thermostat and FAN CLUTCH. An over heated engine will cook a head gasket if it has 100 or 1 million miles.The headgasket discussion is always an interesting one to me. On most other vehicles, headgaskets, main bearings, and everything in between would be toast by 300k. No question. So I think there needs to be a little more perspective when people here say LCs notoriously blow headgaskets. By that metric, every vehicle notoriously blows headgaskets because most don't even make it past 200k without cooling system failures, etc.
I, personally, would never do a headgasket as preventative maintenance. LCs can blow headgaskets when they get hot (like all vehicles). That's not enough reason to tear into something that's working. And if you've been reading on these forums for a bit, you'll see that when people start tearing stuff apart, other things start going wrong too.
If this was an MKIII Supra which had an undertorqued head at the factory, then it'd be a different story. If you want peace of mind, replace the whole cooling system, flush but with no pressure, add a ScanGauge or UltraGauge, and watch the temps. Like you would do on any other car.
But hey, this is, like, just my opinion, man.
I plan on keeping my cruiser till i die. Mine is using oil at a rate of 1 quart every 3 or 4 tanks of gas. I am going to go ahead and do a top end rebuild that should last me the rest of my life. I have 225k on my truck and don't see putting another 200k on it.
