Ordered a handful![]()
!! I've had those on bead locks and the access to the bolt head is QUICKLy gone as the lip is smeared into the opening . JUNK!! I had to grind/cut them down multiple times to get at the bolt head
Yes, lolWhere were you an hour ago?!?!?!?
But once you did you got access to the bolt head right?![]()
Yes, lol![]()
My truck has been on the lift all day while we been measuring everything. Here's is the first draw up of the skid plate for reference.
That does look nice! I thought it was going to be some plates and square tubing welded together.
Why not use countersunk allen head bolts? Obviously you would need to machine the skid plate to accept them.
Ya sounds good for a one off but like I said on the last page, u have to use slotted holes because of frame inconsistencies. And obviously you don't countersink slots. But u can use Allen heads of you want.
Again, not unless you use captive bolts. How do you make it captive? You machine off a few threads closest to the head of the bolt.
That does look a lot better than I was expecting!My truck has been on the lift all day while we been measuring everything. Here's is the first draw up of the skid plate for reference.
What's the plan for the transmission mount studs/nuts?
