Whiteline bushing replacement info
alia176
Tijeras, NM
If you have the 33mm front + 30mm rear whiteline sway bars and are wanting to replace the old bushings, here's the info you need. Their USA website doesn't list them but their AUST website does. I had to speak to one of the USA folks to create an invoice for the part numbers in this post. I bought two kits that contain the end link, and mounting bushings as well as the metal mounting brackets, $80 shipped via FedEx for free.
Incidentally, the rear sway bar originally came with rubber one piece end link bushings, and these are now two piece poly bushings, just like the front. The trick to quickly ID which bushings are for which sway bar, the thinner inner metal sleeves are for the rear 30mm bar. They both have 10mm ID but their OD is different.
