Or it is just normal howl from wearing gears and ignore and enjoy
@PerveanceIt is very interesting that when you removed the front driveshaft, the noise went away (if I read correctly): that immediately made me think transfer case front output shaft or bearing, or pinion.
Makes sense to me. I think I found the OPs final resolution. He commented on his video that when he lifted his GX a few years later, he also replaced the CVs at the same time and one of those, or both resolved this noise. I wonder if it is the angle of the CVs in regards to the dif that did it as opposed to the CVs themselves. Would that affect the preload? I am getting a little bit of steering wheel shimmy at high speeds and some steering wheel vibration when turning in parking lots so I could definitely see it being any of the above, or just have multiple issues going on. I just got the GX so not too familiar with it yet, just tackling one thing at a time.Usually the driveshaft. Can be the preload in the diff, or wheel bearings (unlikely).
Hi, did you finally resolve this issue ? I have similar issue with my GX 460 2014. Its really annoying. It occurs after 30mins of drive and between 20 and 50km/hr.Apart from this noise I'm happy with my GX, so I don't mind repairing it. So far I've done most of servicing myself, but I'm afraid rebuilding tcase is beyond my competence level. Is there any simple way to replace tcase output shaft or does it require opening the tcase which obviously requires removing the tcase from the vehicle?
