Several situations can create ring-and-pinion noise. If the gears have been quiet and begin to howl, they are probably worn or wearing. If the gears howl during deceleration only, it's possible that the pinion-bearing preload has loosened. Howling under acceleration at all speeds indicates that something in the differential -- gears, pinion or carrier bearings -- has worn or no longer keeps the gear alignment correct. If the gears howl while accelerating over a certain speed range, but not all speeds, it's likely that the gears are worn due to lubrication failure or overloading. When a newly installed gear set howls, suspect the design or setup.
