- Joined
- Feb 28, 2005
- Threads
- 123
- Messages
- 2,106
it isn't like they would ever crack a head for no reason, you have to realize people overheat there trucks. How much meat is there wayne, did they make it to break?
sisukid1975 said:What intercooler has been used in the 12HT??? I've been thinking of rigging one up when you guys send me my engine, but am not sure which way to go...
Can the output plenums on the turbo'd side and the intake on the air rail be rotated to pipe the air off towards the radiator to an IC, or would you have to use flexible hoses and bend them around?
I've never seen a 12HT up close and personal, so the day you and sheldon send me mine will be the fist I have ever seen one. It's kinda hard to plan on anything when I'm not quite sure what I have to work with.
Fred
Any suggestions? What about shimming the wastegate-- has that been done on a 12HT?
i think rising sun had an intercooled HJ61 go through a year or so back...Greg_B said:Hi Fred. Any performance shop should have piping on the shelf (flexible or otherwise) to suit. As you can see, the all point up.
I don't know anyone who has intercooled a 12HT.
Shimming the 12HT is simpler then the 13BT. There are two bolts, and no trimming required. I would suggest you install a boost and pyro, get your baselines, then shim. If shimming does not give enough, then a grainger valve would be the way to go.
hth's
gb
nah, i don't think they designed the head to crack. to inspect one and to lift one up you would think that it was bullet proof. it was just a design "oops" that we have to live with.Eric Winkworth said:you have to realize people overheat there trucks. How much meat is there wayne, did they make it to break?
Greg_B said:There is a 12HT of ours in a Troopie in the USA. I believe there was a write-up on Pirates about it.
Are you planning on running Bio-Diesel, or WVO/SVO? I have not kept up on the discussion in this area, however is there comment that IDI is better with SVO and with Bio-Diesel either DI or IDI is fine?
I have found the inline 6's seem much smoother and balanced.
Maybe hit an Ozzie board and ask your question, as they have tons more experience with most of these engines then we do in North America. http://www.outerlimits4x4.com/PHP_Modules/phpBB2/
hth's
gb
fjbj40 said:I might look at taking the old spare head I have and getting a pre-cup and bringing it to a engine shop here in NS which apparently is one of the shops which have been porting for 20 years or so on Nascar engines and see what can be done . That small hole is adding alot of pumping loss and may be a contributing factor to 3b low power output and high EGT's.Daryl
Grease Cruiser said:Greg,
I have seen the 12HT in the troopie that you are referring to. I have even driven it a couple of times. I like it a lot. It is very quiet (compared to my 4BT in my FJ60) and it drives quite nice with the H55F. I have only driven it on pavement so I do not know how it handles offroad.
crushers said:i do not really want to end up like Peter with a pile of parts sitting there with no desire to finish the project.
Greg_B said:3B "Richardson Comet Mark III"
Behemoth60 said:So, the term 'Richardson Comet Mark III' has a dubious origin. If I remember correctly, it actually flew out of my ass a few years ago while typing a message to the DTLC. It's endearing to see that it has actually stuck. Peter Straub
Behemoth60 said:I first heard Rob Mullen make reference to this possibly mis-named combustion process. He was regailing me with a story of attending some institute where they had somehow installed camera's into a diesel engine cylendar to observe the flame propagation. As Rob told me, the instructor made a passing comment about some esoteric footage of some other process, whose name I've re-invented as Richardson Comet Mark III. Rob stayed after class, insisted that he had a truck that used that process, and convinced the instructor to give him a private viewing of the film. Peter Straub
Behemoth60 said:Indeed, I do believe there is a name for the type of flame propgation used in the 3B engine design, but Richardson Comet Mark III may not actually be it, and the use of that term should certainly by in Quotes as Greg has done. If you use it in conversation, I recommend the use of the little rabbit ear air quotes to inflict the dubious origins of that term upon the listener. Peter Straub
actually a cracked head does not afect the performance or power, it affects the cooling system causing over heating and coolant loss. the performance and power stays the same...Behemoth60 said:Some comments...
Marc Ritchie polished the head on his 3B, t... over 250F for extended driving periods, but no noticable effect on power or performance that would indicate a cracking head.
You can goad and taunt me all you like Wayne. I am imunne to your jeers. One day in the far and distant future, I will finish that project, if for no other reason than out of spite.
Peter Straub
crushers said:BTW, they make 3 different head gaskets for the 1HZ. if you want more or less compression you can just change out the gasket...
cheers
Radd Cruisers said:All four engines I have replaced bearings on 2 1HZs, 2 1HD-Ts had at least one bearing showing delamination according the the photos I have seen.Rob
crushers said:this being said i will still change out all the BEB on all HDJ81s that come in. maybe one day i will be able to see what you boys are experiencing...although i hope not to, cheers
Grease Cruiser said:II am looking at scrapping the 3FE/4 speed and going diesel. I am very pleased with my Cummins 4BT powered FJ60, but I am thinking of going with a Toyota diesel for the Troopie. I want to keep this one all Toyota.
