Which of these wheels would you install on your own LC200?
Hello TeCKis300,
I am in a bit of dilemma trying to select best offset for my wheels on my LC200 2011 model.
I have a 285/65R17 tyre (printed on tyre) and 8Jx17 ET60 + 5x150 sized wheel as per Toyota Land Cruiser 2011 - Wheel & Tire Sizes, PCD, Offset and Rims specs
i want to upgrade to 285/70/17 tyres with rims that go with 25mm positive offset, this way it would stick out and look cooler. Then I read about your post about the scrub radius which got me worried.
I calculated the scrub radius via Rim & Tire Size Calculator. Custom Offsets
Then the result from above link said it would affect my handling.
I have a bit more complexity on my LC200 as I just got the suspension upgraded by ARB by installing the BP51s which gave me a 2-inch lift setting, now should this 2-inch be taken into consideration as well? I think so...
Your guidance is appreciated please...
Thanks in advance.
There's a lot of variables to take in to considerations here. Because the IFS pivots, when you raise the truck, the track width does decrease. The factory tire is a 285, will not gain any track with by replacing with the same width tire. Keep in mind, when referring to track width, you have to multiple your offset by two because your scrub radius is for one wheel only. If you switch to a 25mm offset from your current 60mm offset, assuming you stick with a 8" width wheel, you will be gaining nearly three inches of track width.
I am approximately on the same amount of lift, and I am running 285/70r17 on Method MR701. They are 8.5" wide, and have 0 offset. Per the calculator, I am at +58mm scrub, and that is taking no considerations for the decrease in track width due to lift. I can tell you, my handling is not affected by the scrub. The truck feels like a locomotive on tracks, and I have not suffered a noticeable penalty in parking lot maneuvers. It performs really well on the trails because I have a broader base which was the over all goal.
The one issue I am having is increased wear on the outside shoulders of the front tires. My alignment is near perfect, so that isn't the cause. The conclusion I have drawn, is because the front drive axle IS ACTIVE, when turning, more pressure is applied to the outside shoulder as it is actively engaging the pavement. I do have intentions to find a wheel with +25mm offset. It should reduce the rate of wear, but I still expect a higher rate of wear nonetheless.
a related question, my car is a 2011 LX570, factory tire/wheel spec 285/50-20. I wonder if a 275/55-20 would fit? or will have rubbing. Or, if 295/55-20? the 295/55 is close in diameter as factory, although a bit wider but i think there's room.
The link below is a really good resource. You can plug in all your data, to include actual measurements off your truck, and it makes tire size recommendations, and well as shows the affects of changes to tire/wheel specs.
no problem with 275/55. Running 275/60 which is getting very close to rubbing but still good.
