Where to get shock bolts
SC
Hello I'm new to the forum. Just bought a 100 series and noticed the left front shock is sagging and causing the truck to lean. Planning to get the shocks replaced and was looking to replace the lower shock bolts at the same time but not seeing them on any part schemas from anywhere selling OEM toyota parts. Does anyone know where to get these bolts?
Thanks
Let me start with this: the front and rear bolts are different.
But the main problem here, is that replacing your shocks will not fix any leaning--the shock does not hold any weight. (unless you're talking about the Automatic Height Control system...you didn't specify whether you have that, or "normal" suspension) The torsion bars are what you'll need to be looking at. It could be as simple as just needing to adjust one. (or could be something worse, but look there first)
Thanks, I hadn't considered the torsion bars, don't know much about those. I was assuming the shocks because one looks compressed. It is about an inch shorter on the drivers side between the center of the hub and the fender.
I guess I'll start with the adjustment options there. This is a normal suspension, no AHC.
If 90119-14093 Is the front lower shock bolt part # does anyone know the rear lower bolt part #?
