Where to buy 1" front spacers for 80
Normandy Park Wa. ........now in San Diego Ca.
Looking to raise the front one more inch ................anti stink bug
Thanks all
Search for Mr. Gasket 1285. These have a groove on the bottom and a flat top. The 1287 has a groove on top and bottom and will also work. I bought some similar at Pep Boys.
Mike
summitracing.com sells the Mr. Gasket ones as does cskauto.com
I just installed some tonight. Much tougher than I anticipated.
You might PM or e-mail Christo at Slee and see if he has them.
THose are the ones i have. Are they really that tough to install? Seems like it would be pretty easy.
I lifted the entire front end up off the ground and let it fully droop. Then I stood on the wheels to try to get it to droop further. I had to have a friend pry the spring down to get the spacers in. This was tough because they move around. I think if you used a spring compressor it would be fairly easy. I think it might help to disconnect the sway bars. A couple of busted knuckles and they are in now. I thought it would be as easy as swapping the springs but it wasn't quite that simple. Maybe I was just tired?
I'm small enough I was able to get inside the wheel well and push down on the axle with my feet wgile pushing the spcer in. Of course I had the frame on jack stands and the wheels off.
BTW, I used the Mr. Gasket spacers and sourced 'em at the local parts store.
