My turn signals work, but my flasher does not. Wiring is good to the switch.
I just changed mine in a 74 FJ40 this morning. Mine was located on the left side of the dash brace, to the left of the steering wheel, above clutch. It is a small black w/ white box, approx 2"x1"x1", with a black grnd, red and yellow wires. You can remove it by unscrewing grnd from dash brace, disconnecting the red/yellow wires from the wiring harness, and then unscrewing the 10mm bolt holding it in place.
Louis
XTFRITZ....
I had to run power directly to the flaser instead of using the existing power. It is simple to put a fuseable link right off of the fuse box for the power going into the relay. Try that and see if a clean power source for the flasher helps your power issue. Make sure when you try it it is fused. If not, you may have a bad ground and casue damage to go up to the switch in the steering column and the hazzard switch.
If you want, I could draw up how I bypassed the exisiting wiring to make a my own power and flasher circuits.
